Hi,
System
AB SLC 5/03.
1746 - HSCE Card for encoder 1024ppr encoder input.
1746 - N104V 2channel analogue input/output card.
Drive roller dia = 100mm (~4inch)
The machine drive roller pulls material through the machine at about 10m/min
I need to measure the speed of the machine via the encoder and send a 0-10V output to another drive card via the analogue output card.
I assume I will have to convert ppr to rpm and then to a value that the analogue card can use for the 0-10volt output.
I would appreciate any help / suggestions on how to achieve this using the above kit.
Regards,
mrbj
