I 'm not sure my suggestion but i had tested other plc , it ok.
1. you would to have opc server of ab.plc
2. if you have not opc server ab , can use kepware opc server( you can find it on internet and crack)
3.run opc server ab or kepware after run kepware you can add chanel and device ( during select chanal and device you have to set type and comm of plc.
4. after you select chanel and device successful , you can add new item wheen you click add item , you can see method config point example io area , memory area.
5.back to cx-supervisor , you can add point for ab plc by select dde or opc other.
6. after you click select opc comm. from item list you will see kepware opc server or ab.opc server
7. you need to set name group and item , that the same name on opc server
8.I test my method by used cx-supervisor with unitronic plc , siemens s5 and omron . It can work very well .No problem
good luck for you
sathaporn from thailand
