Full Version: Cip to controllogix
Patrick Herbst
i'm trying to set up a generic CIP msg to a ControlLogix to pull the processor status (ie program, run, or fault) and throw it up on a display.  does anyone know that class/instance/attrib to grab this stuff?
Eddie Willers
The easy way would be to perform a GSV instruction in the controller itself, and then interpret the results in a simpler format (i.e. a 1,2,3,4) for the MMI screen to display.
You can do a GSV instruction to the CONTROLLERDEVICE object class, and retrieve an INT data type that contains the status of the controller.
RSLogix 5000 help describes it as follows:
Status INT Bits identify status:
Bits 3-0 are reserved
Bits 7-4 Meaning
0000 reserved
0001 flash update in progress
0010 reserved
0011 reserved
0100 flash is bad
0101 faulted
0110 run
0111 program
Bits 11-8 Meaning
0001 recoverable minor fault
0010 unrecoverable minor fault
0100 recoverable major fault
1000 unrecoverable major fault
Bits 13-12 Meaning
01 keyswitch in run
10 keyswitch in program
11 keyswitch in remote
Bits 15-14 Meaning
01 controller is changing modes
10 debug mode if controller is in Run mode
Of course, if the controller is in Program mode the GSV won't execute and you won't be able to tell.  Hmm.
So you have to figure out what the hex codes for CONTROLLERDEVICE and STATUS are.   I wonder if my handy-dandy CIP analyzer is still around here.....
Eddie Willers
Okay, I *think* it is:
Class      0x01 hex    (Identity)
Instance 0x01 hex    (this one controller)
Attribute 0x05 hex    (Status integer)
Tuesday I'll be able to check this against a real ControlLogix and figure out if it's correct.
Ken Roach
This was answered over at the RSLogix forum recently:
Knowbase A9411 - Checking processor status and memory usage using DDE/OPC reads from RSLinx
Applications that use DDE/OPC with RSLinx can check the status and some other processor information using predefined items in RSLinx version 2.20 and higher.
Status items:
@Status - returns a string containing the current status of the controller (OK or Faulted)
@Mode - returns a string containing the processor mode (Run, Program, Remote Run, Remote Program)
@ProcessorName - returns a string containing the processor name
@Revision - returns a string containing the processor's firmware revision
patrick herbst
Quote (Eddie Willers @ May 24 2002,6:14)
what is this?  and where can i get one?   :-)
