QUOTE(Leadcommander @ Jul 9 2007, 11:22 PM) [snapback]56424[/snapback]
How can you load the .apa file into the Panelview?
If you do this I would be interested in doing it with the several Panelviews I am currently developing.
the .apa file needs converting into a Runtime application this is the .mer file. When using RS View ME and you finish developing the application you select "create runtime application". This converts the .apa file into a .mer. Then using the transfer utility you can download the .mer file
If you just wanted to hold the apa. file in the panel view, you could remove the internal flsah card and using a flash card reader/writer copy the .apa file onto it. the .mer files are in a folder called runtime. try creating an other folder like back_up. I feel this is a bit over the top to hold a back up. and i just store them in serveral places like company server, pendrive etc.
Hope that helps
myles
