My two favorites, a portable resin top table with folding legs and a handle and my folding chair.
I do a lot of work in-plant on control panels where there isn't any place to put a laptop or to work
on an instrument. So my favorite field service tool is my portable bench.
I need a place to setup and work on a PC so I'm not squatting on the floor or holding the PC while
working. Carts are too awkward to carry in a sedan, and trying to scrounge up a cart in someone
else's plant for more than a temporary, couple minute hauling of stuff is a toughie.
So I bought a portable, folding plastic resin table (or bench, if you will) that's light weight with a
top that's 20"x30". I fastened a drawer pull handle on the side at the balance point so it carries
easily in one hand. It's maximum height is only 28", a tad too low for a 6'3" guy, but otherwise
ideal.
Guys in the plant will ask me if I'll iron their shirts for them when I'm done, because the folding legs
look just like your Mom's ironing board. But, hey, if you can't take the heat, stay out of the
kitchen!
With my portable bench and my folding chair and I'm ready to stare at the logic on the
PC screen all day long.
I won't leave the shop without
- 50' extension cord (if you panels don't have Ac power outlets)
- an AC outlet strip, with GFCI with its long 15' cord.
My other favorite tool is Harbor Freights' 100 piece security bit set, that includes 100, 1/4" hex
drive security bits, only 8 of which are duplicates (4 extra #2 phillips, 4 extra #2 pozidrives) all in a
plastic case for $15 regular, $10 on sale. part number 91310.
The only bit it doesn't have, to my knowledge, is the tiny T6 torx size used on cellular phones
cases (my kids bought colored faceplates which require the removal of a tiny torx on Nokias)
Set includes bits:
SAE hex allen (1/16 - 1/4)
SAE hex allen security (5/64 - 5/32)
metric hex allen (1.5-8mm, no 7mm)
metric hex allen security (2 - 6mm)
torx (T8-T45)
security torx (with the bore in the center) (T8-T40)
straight blade screwdriver (metric designations from 3-8mm)
spline drive (M5-M8)
clutch drive (1, 2, 3)
tapered square drive (0 - 3)
3 tine phillips* (1-4)
4 tine offset phillips* (6, 8,10)
2 pin spanner (4, 6, 8, 10)
phillips (0-3)
pozidrive (0-30)
adapters:
male 1/4" hex x magnetic female 1/4" hex
1/4" male hex (fits screwdriver) to 1/4" square male socket drive adapter, one short, one long
Y thingie with 1/4" hex male (don't know what it is)
Highly recommended because all the bits are in one place - the red plastic box.
You do need a hex bit screwdriver, though.
Other tools:
A requisite is a set of long leads (15 footers) for the DVM
signal source: 4-20mA unit
ethernet crossover and straight cables.
ethernet 4 port switch with its AC power supply adapter
paper clips (put 'em under screw terminals so the alligator clips can grab something besides a
round screw head)
10 ohm, 68.5 ohm & 250 ohm precision resistors (for various AI shunt resistors)
AA & AAA batteries
A digital camera with 3x optical zoom, to 'document' situations 'as found' and/or 'as finished'.
A set of miniature screwdrivers that fit the screws on terminal blocks.
A Wago spring release 'screwdriver' (what do they call that thing, anyhow?)
For firmware updates, I carry a smaller 350VA or 400VA UPS to ensure that power doesn't fail
during the firmware upload.
DB9 serial straight cable, DB9 serial null modem cable, DB9 sex changer adapters F-F, M-M
Brother P-Touch label machine and a couple spare label tapes (I mark everything ! !)
Dan
