Full Version: micrologix 1100 webserver
kcor
[attachmentid=4620]Have a question that I hope someone can help with.
I have connected to a micrologix 1100 that I ordered at my workbench.
I have configured the ip address of the 1100 as well as my PC, and can connect to the 1100.
I can then open internet explorer and type in the ip address of the 1100 and connect to it through internet explorer through the micrologixs 1100 embedded webserver.
chapter 2 of the manual describes how to use the data view.
I can open up the outputs as it shows on page 2-3 of the manual and see the state of the outputs.
I wrote a simple program to turn on output 0.
I can then go to the internet explorer, select view refresh across the top of the page and see that output 0 is now true.
I can go back into the progam and change the program so the output 2 is off, then if I open internet explorer back up, it still shows output 0 as on. I have to manually select view - refresh across the top of the internet explorer page to see the state has changed.
Is this something that you will not see in real time.
I thought that if i connected to the 1100 through the embedded webserver and was monitor outputs, inputs etc. that I would see them change as they changed on the plc.
Is there something that I am overlooking.
thanks
swimmy67
I believe the web server is set to refresh every 30 - 60 seconds. The web server will not show real time I/O updates.
I hope this answers some questions.
kcor
QUOTE(swimmy67 @ May 2 2007, 05:44 PM) [snapback]53655[/snapback]
Yes thanks, had a case of going brain dead, was in a big hurry to get out the door.
Ever have one of those days.
What I am trying to do now is reference some of the outputs in a excel file and link it to the output through the web server and have the excel file update the status.
rpraveenkum
use this utility to auto refresh the IE
http://forums.mrplc.com/index.php?showtopi...E6+auto+refresh
kcor
thanks
will give it a call next week
