I can use the ETHIP to connect to multiple processors using a hard wired cable if I disable my wireless ethernet port. Likewise I can surf the internet using my wireless connection if I disable the wired ethernet port. If both are enabled, I can fool around with the binding and do one thing or the other, but not both without going through the enable/disable procedure. I tried bridging them via Windows XP network setting, but then nothing works. Is there some setup that allows both to work without disabling one or the other?
Some specifics:
Windows XP Pro
RSLinx 2.50.00.20 cpr 7
All A-B devices on wired ethernet are 172.20.1.XX
Thaks in advance.
