My local support gave me this info from the Rockwell site.
I brought the unit to work and tried downloading via DH+ and still got the same message.
It seems that maybe this was taken oiut of sevice while an edit was taking place or had an EEPROM at on time and is still looking for it. I don't have a memory module to try the "back door" approach. So for now I'll have to wait untill I find one. -Bummer[url="java script:emoticon("][/url]
Thanks for the help guys,
Luke
ID 18360 Products Programmable Controllers
SLC500 (1747)
Category (optional) General
Date Created 06/23/2000 Last Updated 11/03/2006 Access Level Everyone Prev. TN# G18579
Print Answer
Email Answer Download Failed! Could Not Get Processor Ownership.
Question Download Failed! Could Not Get Processor Ownership
Answer
Problem:The following error was generated when attempting to Download to a processor:
Cause #1:A previous Online Edit failed, thus leaving the processor in Online Edit status.
Solution #1:Cycle power to the processor and re-download. If this fails, try solution #2b.
Cause #2:RSLinx Super Who would see the processor. The User was even able to go Online with the processor, but would always generate the error when attempting to Download. The cause of the problem was that the Write Protected bit was enabled under the General Tab of the Channel Configuration.
Solution #2a:Download using a different channel.
Solution #2b:Factory default the processor and re-download without the Write Protected bit cleared.
Cause #3
The user can go online with RSLogix 500 and monitor I/O. Online edits and program download do not function. The program Compare bit (S2:2/9) is set and an EEPROM is installed in the processor.
Solution #3
If the Auto Load bits are not set skip to step 5.
While ONLINE -- go to REMOTE PROGRAM and UNSET bit S:1/10, S:1/11 and S:1/12
Store to EEPROM while in REMOTE PROGRAM
Save the program while in REMOTE PROGRAM
Go OFFLINE
Power down
Remove memory module
Power up
Unset the S:2/9 bit
Redownload the program without the memory module
Save the program
Power down and put memory module back in
Power up
GO ONLINE -- REMOTE PROGRAM
Store to EERPOM
Go back to RUN Catalog Number: 1747L511;1747L514
DocFullNum: G18579
Revision:
Fixed in Revision:
Package:
Modual:
