QUOTE(paulengr @ Mar 1 2007, 06:13 AM) [snapback]50702[/snapback]
QUOTE(stickman47 @ Mar 1 2007, 03:16 AM) [snapback]50691[/snapback]
I have a WinBook Laptop running Windows2000 Pro SP4, that we use to program our Allen Bradley PLC's. I needed to access a network printer so I connected the computer to our network and set up a local area connection to the printer. All was well until I disconnected the network. Now my RsLogix 500 English CP7 will not run unless I am connected to the network. I get an error "Copy protection license for the application could not be acquired: Error 2. Since I don't have network access out i the plant I am screwed unless I can correct this mess. Any takers ??
One of two things happened. Either you corrupted your license, or you moved it somewhere. You are currently using a license stored on network drive somewhere.
Use the evmove/evreset commands to figure out where your licenses are or aren't and fix them.
I tried that. I am only loged on to one network drive and EVMOVE didn't find it there. I searched the entrie network for EVRIS.SYS but couldn't find that either. even the 386swap file is missing from the rockwell directory. I can't imagine where, or how this happened. I wonder if they would give me a reset code ?
