I am running Proficy 5.5 sim8. I have requested 5.6 cd. The screen is a View (CE) screen. IC754VSICTD. I amusing the CLX driver under AB Ethernet I/P. I have three issues.
1. The array read under this driver reads the first tag and what ever the value of that tag is, proficy populates the array with that value. So if the first value is 100, The array reads back OIM[100,100,100,100], rather than the next value. So I had to go to individual tags.
2. I set up more than one device so that I could have faster updates of control tags over the metering dispay tags. This works on a couple of screens but not all, even though the projects were cloned from one that worked.
3. I have problems where one view screen is setting tags other than its own. I can actually see in the plc where one of the view screens is setting tags that are not even in its application.
I have looked at trying to convert to PL5 or SLC500 tags however this means reprogramming every tag in the base application. But given the way Proficy handles tags I have been reluctant. GE is sending some tech guys down to look at it today. I will post what they find. If they can't make it work, I am screwed big time. I have two lineups that have already shipped and 3 more in production. The threshold seems to be 5 screens and 4 ab flex i/o drops. After that the system becomes unreliable.
Thanks for the input
Slcman I re read your note. I only have AB TCPIP driver. No dedicated CLX driver. See version above.
