Hello,
I am trying to connect several tags from my PLC(CompactLogix 1769 L31) to my HMI(Panelview Plus 600) and am having trouble creating a runtime application due to an error that states that it is
"unable to save tag database". I am linking my PC which is running RSviewME to the PLC. It seems to recognize the correct PLC device and I can correctly see/connect the PLC ladder logic tags to the HMI buttons etc. The problem only occurs when I try to run/create a runtime application. Can anyone point me in the right direction as to what is causing the error to occur, or what I can do to remedy this.
Thank you in advance
