Thanks for idea.
I try to setup the maximum range to 4095 and it works but I have different zero position of encoder reading and machine. I adjust machine zero (home) position and reset the encoder to zero but the reading is always different (around 115 deg). How to make it same? Any idea ?
Thanks for suggestion.
Regards,
James
QUOTE(panic mode @ Feb 8 2007, 05:28 PM) [snapback]49484[/snapback]
Hi James,
Just setup counter range in HSCE2 and it will roll over automatically....
Actual range will depend on resolution of encoder (we know it's 1024ppr),
configuration of HSCE2 (if you are using X2 or X4, you need to multiply PPR by 2 or 4),
and gear ratio (encoder to machine coupling - just another factor to multiply result).
