QUOTE(finfin @ Jan 18 2007, 01:03 PM) [snapback]48077[/snapback]
I have a problem that if I type in text and align it to a numeric display on a screen that is to be resized at runtime; The text and numeric input are miss-aligned left to right when I run the app.
Can anyone help me with this?
You need to select Center justification. It is located on Tag assignment screen when ever you select a new numeric display or edit a previous
Example:
You need to select Center justification for each numeric display.. It is located on Tag assignment screen when ever you select a new numeric display or edit a previous display. The default is right justification. You will see this alot. Get used to it. Numeric Entry, Label, String input, and so on.
[attachmentid=4027]
