I occasionally have to design control panels for exterior use (NEMA 4X) which also may have to be UL listed (UL508). The last time I did that, the UL inspector had a problem with the insulation that I used on the interior panel surfaces. I typically use a 100W Hoffman heater for anti-condensation. The insulation I use is 1/2" foam sheet (Nomaco K-Flex). I suppose one of the options I have is to forget the insulation and oversize the heater (Maine winter conditions).
Does anyone have a different approach to this problem? Thanks.
