Geez...just got my new ML1100 to use for the first time.
I get all kinds of errors when I try online edits...I think I am gunna stay away from it for now. I looked at a few things...I have RS Linx 2.51 and RS Ladder 7.0 using a series A ML1100.
AB KB says this below, but no real "solution". Are they gunna come back to this article and update it?
I changed my resource time out default from 60 to 100. That didn't seem to work too good either. Anyone have any suggestions to stabilize the online edits?
Copy Paste from KB, since we can't link to them anymore......
On-line editing requirement in RS Logix 500 version 7.00 , RS Linx 2.500, and firmware revision series A frn 1 of a ML1100..
Question
Answer
Attempting to perform an online edit in a ML1100 processor fails with "Program could not be compiled! Online edit error. Going Offline" This error is seen whether attempting to perform an online edit from either the serial or ethernet port if no ladder has ever existed in that processor or after processor memory has been cleared.
Cause: At least one rung of logic must be downloaded to the processor or error is generated. Rung (not processor) can then be deleted later with no online edit problems.
Summary: Attempting to perform an online edit in a ML1100 processor fails with "Program could not be compiled! Online edit error. Going Offline"Catalog Number: 1763-L16AWA;1763-L16BBB;1763-L16BWA
DocFullNum: A132937083
Revision:
Fixed in Revision:
Package:
Module:
More copy and paste.....
Cause:
The "Edit Resource/Owner Timeout" on the "General" tab for channel 1 is set to 1 or some small number.
Solution:
Change the "Edit Resource/Owner Timeout" to 60 (Default value is 60)
And this is my favorite, change to 60, even if the default is 60...huh?....weird....
edit....
I get this alot too...
"Online edit resource cannot be obtained from processor."
Cause, unknown, and the fix is power down, power up....sigh.....
Question
Answer
Problem
This error message appears when trying to accept edits online. If changes are made offline and then downloaded, this error will appear: "Program is incompatible with processor."
Cause
Unknown; possibly a loss of communications while online.
Solution
Cycle power to the processor. If that does not work, you can try changing the processor type in the offline file, resizing data tables, and then changing the processor back to the original (correct) type and downloading.
Catalog Number:
DocFullNum: E8885
Revision:4.50
Fixed in Revision: N/A
Package: Offline/Online
Modual: Editor-Online
