QUOTE(BobLfoot @ Jan 16 2007, 08:07 AM) [snapback]47884[/snapback]
I am not familiar with the OP270 from Siemens, but if it can do the DF1 protocol then it should be a candidate for 1761-NET-ENI. The connection would look like OP270 to 1761-NET-ENI to Ethernet to CompactLogix with Etherenet.
Maybe that is possible, maybe not. I have never used a NET-ENI, but as fas as I understand, it uses a rarely used part of the DF1 setup ("node ID" I think, or something like that) to let the NET-ENI know which IP addresses to use for transferring the addresses. I would not be too sure that the OP270 supports this part of the DF1 protocol.
