Hi...
I used Micrologix 1100 (1763-L16BBB) pulse train output (output 2 and 3) and the common is connected to dc com (using npn configuration). I have to connect to Panasonic servo drive: output #2 to drive #1 and output #3 to drive #2. I have the problem if I connected both outputs to two drive and initiate the pulse (20KHz ), all drives is not run but the output 2 and 3 is blink. If I connect only one channel to one drive then the drive is run.
How to solve this problem? I need any suggestion or idea.
Thanks.
james
