QUOTE(mulderm @ Jan 13 2007, 11:58 AM) [snapback]47783[/snapback]
Hello,
Can I connect the Panelview Plus 700 with a DH+ connection
on the programming port (9-pins) from the PLC5/25?
I know that normally must this connect to the 3-wire DH+ connection under the programming-port but there is 2 DH+ cables connected to there so there is no place.
The programming-port have the same connection as the DH+ 3-wire
connection on the processor?
Greetings,
mulderm
If you can bring the system down to program modethe following will work.
Option A
IF your two cables landed at the 5/235 for DH+ ware called Cable1 and Cable2. Then remove Cable 1 and land it at a terminal block. Run a cable 1A from the TB to your PV. Run a calbe 1B from the PV back to where Cable 1 was landed. I know this uses 12 meters of blue hose for s 6 foot run but it will work.
Option B
IF your two cables landed at the 5/235 for DH+ ware called Cable1 and Cable2. Then remove Cable 2 and land it at a terminal block. Run a cable 2A from the TB to your PV. Run a calbe 2B from the PV back to where Cable 2 was landed. I know this uses 12 meters of blue hose for s 6 foot run but it will work.
