Full Version: 1746-HSCE
mac_g3
Hello All.
I'm French, and my English is not better !
I have a machine with SLC500 system, the PLC have a 1746-HSCE high speed counter module.
The machine is brand from the USA, the original encoder AB model 845H is broken mechanically.
Then, i want to replace the encoder with European model ( the brand is IVO industries ), model GI355 ,
with same type differential outputs, supply voltage ,and point per turn.
After wiring the nex encoder, the three signals a, b, and z is been present in the 1746-HSCE ..
i can see the led's turn on and off when i turn with my hand the encoder axe.
The 1746-HSCE increase or decrease counts normally with the rotation CW or CCW of the encoder,
but the accumulated counts .... is never reset to zero.
The settings of the 1746-HSCE is good and not modified ... after check, the reset module
is been with Z input only.
Next, i see in the 1746-HSCE manual ... the module need to reset correctly ...
at the end of each turn, the channel Z is true, and the channels A and B is false ....
My encoder not have the same waveform ... at the end of each turn, the Z channel is true .... if
the channels A and B is true ....
Anyone have idea to get a correct waveforms needed by the 1746-HSCE ?
Any help graetly appreciated.
Greetings from France,
Stéphane.
P Daniil
Greetings Stephane.
The exact position and length of the index mark (Z signal) in the A-B cycle is always a problem when replacing encoders.
As your encoder has differential outputs, try swapping the A with -A and B with -B encoder output wires at the controller input. This should change the A and B polarities (getting a high Z with A and B low), but with the side-effect of shifting the whole 360 degree cycle by half an encoder resolution cycle.
Normally this shift is not a problem in incremental encoder applications.
Good luck.
mac_g3
Hello P.Daniil.
Very thanks for your answer.
In first, because the longtime of the downtime of the machine, my boss
say me to search a reseller to purchase a original encoder 845H
( from Rockwell Automation ), and after mounting, the machine is now running ok.
Today, after machine ending production stop of the day,
the machine is off, i have a free time, and then i try to make your tip
(wire A+ swapped to A- , and B+.swapped to B-) with my encoder European model.
And ... bingo !!! ... all is ok ..!!! ...the accumulated counts is reset to
zero at the end of each encoder turn, the Z channel is been true
when the A and B channels is false.
This help is very great for me ... this is a best way to replace original parts from USA
( cost high .. and hard to find in France !! ), by European parts .... at low cost and easy
to find in France.
I again thank you very much for your precise and concrete help.
Thanks, greetings from France, and happy new year !
Stéphane.
