OPC and RSlinx using Visual Basic 2005
  • Please log in to reply
10 replies to this topic
#1 TechJunki
TechJunki
    Sparky
  • MrPLC Member
  • PipPipPip
  • 272 posts
  • Country:United States
    United States
Posted 11 October 2006 - 02:41 AM
I recently downloaded the new Visual Basic 2005 Express version from Microsoft for FREE, yes I said free. I know I have seen quite a few posts about using OPC with with the newer .NET versions of VB. Being quite comfortable with VB6 and OPC i gave this a shot and have successfully compiled code for both SyncRead and AsyncRead operations. I have not yet looked into the write operations but thought I would post the code I have for everyones viewing pleasure..
If anyone has an older version of VB.. .NET 2003 or .NET 2002 I would be interested in knowing if this code is compatible.
++ Be sure to add the reference "Rockwell Software OPC Automation" ++
Imports RsiOPCAuto
PublicClass Form1
Public MyRsLinxOPCServer As RsiOPCAuto.OPCServer
PublicWithEvents LinxOPCGroup As RsiOPCAuto.OPCGroup
Public LinxItem1 As RsiOPCAuto.OPCItem
Public LinxItem2 As RsiOPCAuto.OPCItem
PrivateSub Form1_Load(ByVal sender AsObject, ByVal e As EventArgs) HandlesMyBase.Load
Dim ItemCount AsShort
Dim TransID As Int64
Dim CancelID As Int64
Dim i AsInteger
'Create Server
MyRsLinxOPCServer = New RsiOPCAuto.OPCServer
'Connect to Server
MyRsLinxOPCServer.Connect("RSLinx OPC Server")
'Add Group to Server
LinxOPCGroup = MyRsLinxOPCServer.OPCGroups.Add("TestGroup") 'Group name can be anything you want it to be
'Set Group Active for Data Updates and Events
LinxOPCGroup.IsActive = True
'Group Update Rate
LinxOPCGroup.UpdateRate = 1000
LinxOPCGroup.IsSubscribed =
True
'Add Items to Group, the specifier on the end Needs to be Unique for each Tag
LinxItem1 = LinxOPCGroup.OPCItems.AddItem("[PLC_TOPIC]TAGE_NAME1,L10,C1", 1)
LinxItem2 = LinxOPCGroup.OPCItems.AddItem(
"[PLC_TOPIC]TAGE_NAME2,L10,C1", 2)
EndSub
PrivateSub SyncRead_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SyncRead.Click
Dim i AsInteger
'Get Number of Items in Group From Server
ItemCount = LinxOPCGroup.OPCItems.Count
'Dim Arrays for SyncRead
Dim SyncServerHandles(ItemCount) AsInteger
Dim SyncErrors As System.Array
Dim SyncValues As System.Array
'Pass in the ServerHandles for the items
For i = 1 To ItemCount
SyncServerHandles(i) = LinxOPCGroup.OPCItems.Item(i).ServerHandle
Next
'Read Items From Group
LinxOPCGroup.SyncRead(1, ItemCount, SyncServerHandles, SyncValues, SyncErrors)
Dim MyData As System.Array
MyData = SyncValues
EndSub
PrivateSub AsyncRead_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles AsyncRead.Click
Dim i AsInteger
Dim AsyncServerHandles(ItemCount) AsInteger
Dim AsyncErrors As System.Array
Dim AsyncValues As System.Array
AsyncServerHandles(i) = LinxOPCGroup.OPCItems.Item(i).ServerHandle
Next
'Execute statement to Read Data from Group
LinxOPCGroup.AsyncRead(ItemCount, AsyncServerHandles, AsyncErrors, TransID, CancelID)
'Call Sub When Read is Completed --
AddHandler (LinxOPCGroup.AsyncReadComplete), AddressOf LinxOPCGroup_AsyncReadComplete
EndSub
PrivateSub LinxOPCGroup_AsyncReadComplete(ByVal TransactionID AsInteger, ByVal NumItems AsInteger, ByRef ClientHandles As System.Array, ByRef ItemValues As System.Array, ByRef Qualities As System.Array, ByRef TimeStamps As System.Array, ByRef Errors As System.Array) Handles LinxOPCGroup.AsyncReadComplete
MyData = ItemValues
EndSub
End
Class
  • Attached File  Code.txt   3.47KB   2090 downloads
Edited by TechJunki, 11 October 2006 - 02:50 AM.
#2 Guest_trn_psycho_*
Guest_trn_psycho_*
  • Guest
Posted 11 October 2006 - 12:39 PM
That's defiantly a start, but I keep getting an error when it reaches this operation:
It may just be because I've tried to convert it to C#, but it says that there isn't an overload for SyncRead that only takes 5 arguments. It's looking for 7. The last two are quality and timestamp objects?????????????????????
Edited by trn_psycho, 11 October 2006 - 01:39 PM.
#3 TechJunki
TechJunki
    Sparky
  • MrPLC Member
  • PipPipPip
  • 272 posts
    United States
Posted 12 October 2006 - 01:52 AM
I added the last two arguments as Objects in VB an it still works fine. Does the AsyncRead work??
Dim SyncQualities As Object
Dim SyncTime As Object
LinxOPCGroup.SyncRead(1, ItemCount, SyncServerHandles, SyncValues, SyncErrors, SyncQualities, SyncTime)
Edited by TechJunki, 12 October 2006 - 01:55 AM.
#4 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3173 posts
  • Gender:Male
    United States
Posted 12 October 2006 - 04:37 AM
Care to share the URL and save us all a lot of searching?
BobLfoot
"Poor Planning on your part does not a crisis on my part make"
#5 Bob O
Bob O
    Sparky
  • MrPLC Member
  • PipPipPip
  • 484 posts
    United States
Posted 12 October 2006 - 05:05 AM
This should get you going....
http://msdn.microsof...studio/express/
I started taking the class this quater and was told that downloading and installing from the NET was a PIA. My copy came in the text.
Hope this helps,
Bob
#6 Guest_trn_psycho_*
Guest_trn_psycho_*
  • Guest
Posted 12 October 2006 - 09:14 AM
No... But I figured it was for the same reason... After adding them in, I"m faced with more errors. (I may have to just stick with VB on this.) For starters, it's telling me that there are invalid arguments. Then when I correct what I think is an invalid arg, I'll get messages about not being able to convert type System.Array[] to int[]. I've tried playing with different types for the calling function, but there is too much type conversions going on that you don't have to worry about in VB that C# just screams about!
#7 autocontrolit
autocontrolit
    Sparky
  • MrPLC Member
  • PipPipPip
  • 43 posts
    United States
Posted 12 October 2006 - 11:17 PM
Cool I just started working on a project using Visual Studio 2005 to build a Data Collection package can you show a screen shot of the form you are using? Also here is a link I found helpful from AB it is using OPC connection Sync and Async reads in a Excel Spreadsheet (VBA).
http://domino.automa...5256AFB0059FE9F
#8 jmbvianney
jmbvianney
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 2 posts
    United States
Posted 04 October 2007 - 02:28 AM
Thank you for an excellent example. I modified it to use with a PLC 5 and have been able to read individual PLC words using it.
However, I would like to read and write entire blocks and so far have not been able to accomplish that. It appears that
your example is for Control Logix.
In your code, the following line appears to contain a length designation 'L10'.
I have not been able to translate this line into something that lets me read more than a single word of data.
After a lot of searching and little success it seemed to me that I needed to instead use AddItems rather than AddItem.
With AddItems, I have not been able to figure out how to define the second parameter in the method (ItemIDs). The method wants an array but it also needs to know 'where to look'. So I am quite confused about how to achieve block reads/writes.
From the Visual Basic 2005 Object Browser:
AddItems(ByVal NumItems As Integer, ByRef ItemIDs As System.Array, ByRef ClientHandles As System.Array, ByRef ServerHandles As System.Array, ByRef Errors As System.Array, Optional ByVal RequestedDataTypes As Object = Nothing, Optional ByVal AccessPaths As Object = Nothing)
Any help would be greatly appreciated.
Thanks,
#9 sadlerej
sadlerej
    Sparky
  • MrPLC Member
  • PipPipPip
  • 41 posts
    United States
Posted 04 October 2007 - 07:53 AM
I have recently completed a project that uses Microsoft visual basic 2005 express edition, Microsoft sql 2005 express edition and Microsoft report server. I gather data from my machine using Softwaretoolbox opc server bring that into vb 2005 EE from there log the data to sql server (download the advanced sql) it has Business Intelligence Development Studio that has Report Server built in. Report Server is a handy tool for creating simple web pages to display on your intranet. The one thing to watch out for with 2005 EE is that vb and sql need to be on same machine (no remote access of database).
#10 Mickey
Mickey
    Propeller Head
  • MrPLC Member
  • PipPipPipPipPipPip
  • 1539 posts
    United States
Posted 04 October 2007 - 09:35 AM
Thanks,
You might find this useful:
http://www.plctalk.n...ht=free utility
#11 kiyoung
kiyoung
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 1 posts
  • Country:Korea - South
    Korea - South
Posted 12 March 2009 - 10:16 PM
Thank you for excellent example.
please help me to understand the meaning of following line. Especially I have no idea about "L10" and "C1"....
