tashinz, on Oct 30 2007, 05:31 AM, said:
some redo option would be quite helpful. also undo option often behaves in unexpected manner, so it should be improved.
I agree with the trending, I think that bobb highlighted this a while back. Being able to select
a user-defined window, rather than the current option of full plot or the sampling period that has
been configured.
Also, the undo function is odd, it is not consistent with what it 'un-does'.
I think this has been mentioned already, but being able to animate the graphics. This can
be done with created objects, but not with items from the graphics library. The same applies
for modification of the properties, you cannot rotate some items for example.
