CX-Supervisor improvement requests
  • Please log in to reply
67 replies to this topic
#31 banker
banker
    Sparky
  • MrPLC Member
  • PipPipPip
  • 112 posts
  • Country:Denmark
    Denmark
Posted 09 October 2007 - 02:01 AM
Hi
Not started to use CXS ver.2 yet. But for ver.1.3x
1. Make an option so you can control where the Alarm pop screen appear on the "main" screen. (use full when working with dual monitor )
2. Make an option for disable CXS to start 2 times at the same time.
Banker :shrug:
#32 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
  • Country:Yugoslavia
    Yugoslavia
Posted 10 October 2007 - 09:41 AM
they should implement some kind of object properties, like in cx-designer. so, e.g. one can change position, domensions, color, point assignment of the object etc. this could also allow group editing (again like in cx-designer). access to the object through workspace window is not sufficient.
Edited by tashinz, 10 October 2007 - 09:41 AM.
#33 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
  • Interests:Too many...
  • Country:Netherlands
    Netherlands
Posted 10 October 2007 - 06:32 PM
Hi
Banker :shrug:
Good points there, but I don't think there will be functional updates for 1.3, if any... Let's hope they will be implemented in V2. Although I believe running 2 runtime instances isn't possible ? Or do you mean the developer ? I like that feature so you can easily compare 2 projects!
#34 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 11 October 2007 - 05:30 AM
I have an application with 5 cx-s 1.33 runtime instances on one computer. tried to avoid that but customer wanted it that way. anyway...it works perfectly and this apps are quite big i must say, works on ethernet. this shouldn't be disabled, both in runtime and developer. what's the use of it anyway?
#35 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 15 October 2007 - 03:02 AM
I would like to have a "Select all" command in the right mouse button menu, or CTRL+A to select all objects instead of opening the Alarm editor (does not comply with standard Windows commands).
Now I have to go to the Edit menu everytime I want to select all objects.
#36 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 15 October 2007 - 09:45 AM
If I have the Project workspace window opened, and I select an object on the page it is highlighted in the workspace with a very light grey background, hardly visible:
Posted Image
But when I select an object directly from the workspace by clicking the reference the selection color is much better.
Posted Image
I would like to see both selections using the same background colour. (of course the last one :-) )
Oh and anyone else having trouble quickly finding a command from the file menu ? Imo too many options, I suggest putting ALL project related commands back in the Project menu like before. Besides, the Recent Projects and Recent Pages function is very useful, but should be placed on top.
Also more icons should help recognise commands.
This is how I would like it.
File menu: (Perhaps name it Page menu ?)
Posted Image
Project menu:
Posted Image
#37 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 15 October 2007 - 04:38 PM
wanted to post the same as PdL in last two posts. you wouldn't believe it.
Edited by tashinz, 15 October 2007 - 04:39 PM.
#38 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 15 October 2007 - 04:41 PM
LOL did you go to work this morning as well ? Now that would be creepy :-)
#39 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 15 October 2007 - 05:09 PM
sure i went to work, but you're right Pim, very tired I am. was commissioning in Bosnia these days, heating plant. and since the heating season started today, everything was urgent of course. moving on to the next project allready. and so forth, till the day I retire in about 30 long years.
#40 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 17 October 2007 - 05:20 AM
There seems to be a problem in selecting objects within an object group using the workspace.
Sometimes when I select a group to edit the individual objects belonging to that group, the workspace only shows the animations configured for this group, but not the underlying objects and their animations.
When I close the workspace and open it again, and select the same group, all objects appear again under the group.
Selecting group 32:
Posted Image
After closing- and reopening the workspace:
Posted Image
#41 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 17 October 2007 - 07:55 AM
Regarding the point editor:
  • I would like point groups to NOT automatically be deleted when all its points are deleted.
  • I would like to be able to add, edit, and delete (with confirmation of course) point groups regardless of existing points or not in a group.
As a workaround I use a dummy memory point and put the point view filter on I/O points to be able to remove all (visible) points without the group being removed, but now I am setting up a new project and only work with memory points...
  • I would like to have a group name column when bulk editing points in Excel so I can paste points back at any location in the point editor. Then when a name doesn't exist CXS should give a message the group name doesn't exist, with a choice to add the points in a new group or to cancel pasting points.
  • When pasting points with duplicate point names I would like to have the choice to replace, cancel or rename the points just like CX-Programmer.
  • As an alternative to bulk editing in Excel a find and replace function for point names
The same options I would like to have for the alarm editor.
That's all :-) I am not too demanding right ?
#42 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 17 October 2007 - 09:11 AM
Never noticed it with V1.3, but I guess its not a new thing.
When you change the properties of the Edit Point Value (Analogue) or the Edit Point Value (Text) animation such as point name, caption text or minimum/maximum values and after this check any of the options "Echo Off", "Display Numeric Keypad", "In Place Edit", the stored values for these properties are loaded again.
Strangely enough it does not go for the Edit Point Value (Digital) animation or any of the Display Value animations.
#43 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 18 October 2007 - 02:41 AM
When opening a CXS project in V2.0 by opening the *.SCS file from Windows explorer (double clicking), a message pops up telling the installation is not licensed. This only happens when opening a project this way. For the rest the developer opens the project normally and it doesn't seem to affect anything...
Posted Image
#44 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 18 October 2007 - 04:15 AM
There seems to be a bug in the script mode radio buttons in the script editor as described in this topic.
#45 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 18 October 2007 - 04:22 AM
Hm... this happen to me a few times. but I realized why. since we bought cx-s 2.0 upgrade and I installed that on Vista machine without prior installing cx-s 1.3, that message kept appearing. after I install first cx-s 1.3 and then cx-s 2.0 never saw this message again, both clicking on the .scs in explorer or by open project.
Edited by tashinz, 18 October 2007 - 04:22 AM.
#46 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 18 October 2007 - 04:53 AM
The display page / close page dialog window needs to be sizeable or the window needs to be made wider. When using long duplicate page names with different numbers at the end, these numbers are not visible.
Now I have to count rows. :-)
Posted Image
#47 banker
banker
    Sparky
  • MrPLC Member
  • PipPipPip
  • 112 posts
  • Country:Denmark
    Denmark
Posted 25 October 2007 - 05:04 AM
IF you open the same instance 2 times at the same time. I can happen that the CMD files can be damaged
And you are not able to open the project again before replacing the CMD files.
It has happened for me a couple of time. :-(
I also thing it shall only be an option you can select / deselect
Banker
#48 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 25 October 2007 - 06:54 AM
it would be great if the vertical axis limits in Data Log can be specified indirectly. there is often the case that customer needs to rescale y-axis.
#49 Berti Baker
Berti Baker
    Sparky
  • MrPLC Member
  • PipPipPip
  • 223 posts
  • Country:United Kingdom
    United Kingdom
Posted 25 October 2007 - 10:51 AM
Don't forget the designer can specify different maximums for each trace and the customer can override from View menu->Scale Settings. These are always enough for me!
I'd like to see some extentions to the Application Analysis though to detect more dodgy programs
Bertie
#50 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 26 October 2007 - 07:43 AM
yes, but that overrides vertical scale for all displayed items, so that is basically the same as turning on the percentage display, only this way some items can be out of new scale. almost allways, after commisioning, after some time during which the customer relates with application, I had to send him a new runtime file with new scales for data log viewer.
also, since the percentage display shows analogue items in percentage of their pre-defined scope, it would be good if operator can see what are the min and max values of displayed items so the value of 23 % has the meaning 23 % of 0-500C scope.
also it would be great if one could select some period of time in data log viewer and see desired items in that period only. it is often asked.
totally agree.
#51 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 30 October 2007 - 05:31 AM
some redo option would be quite helpful. also undo option often behaves in unexpected manner, so it should be improved.
Edited by tashinz, 30 October 2007 - 05:41 AM.
#52 scottmurphy
scottmurphy
    Out of Control
  • MrPLC Member
  • PipPipPip
  • 366 posts
  • Country:New Zealand
    New Zealand
Posted 30 October 2007 - 12:41 PM
I agree with the trending, I think that bobb highlighted this a while back. Being able to select
a user-defined window, rather than the current option of full plot or the sampling period that has
been configured.
Also, the undo function is odd, it is not consistent with what it 'un-does'.
I think this has been mentioned already, but being able to animate the graphics. This can
be done with created objects, but not with items from the graphics library. The same applies
for modification of the properties, you cannot rotate some items for example.
#53 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 24 December 2007 - 08:33 AM
The auto save feature behaves strange. if you set up the auto save for 10min cycle (default), you normally make changes on your project, and if you want to exit scada and discard all the changes it is not possible if the autosave feature has just done its job. then I cannot undo, nothing. autosave should guard you from sudden crashes not to save my project without my allowance. as backup, right? this is not the case here so it should be improved.
#54 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 26 December 2007 - 05:35 AM
sometimes, not often, but sometimes, I have a field in cx-s that should display the value from plc in hexadecimal format i.e. if there is a value AF1D in D100 in plc that should be displayed in scada. also it has to be edited in hexadecimal format.
this is not possible now. it is possible in NS and NT. for now, I have to write script for this simple feature.
Edited by tashinz, 26 December 2007 - 05:36 AM.
#55 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 14 January 2008 - 09:55 AM
there is a cx-s 2.1 (15) upgrade on omron download site. still nothing of find / replace feature but they put an option to compile project to cx-s 1.3 target. this is great.
#56 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 16 January 2008 - 06:20 AM
How does this work Tashinz?
#57 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 16 January 2008 - 08:47 AM
didn't test it in a production enviroment, but here in office it works. so far.
#58 PdL
PdL
    Propeller Head
  • MrPLC Admin
  • 3053 posts
  • Gender:Male
    Netherlands
Posted 16 January 2008 - 09:00 AM
LOL I meant how do you compile to 1.3 target file ?
#59 tashinz
tashinz
    Sparky
  • MrPLC Member
  • PipPipPip
  • 369 posts
    Yugoslavia
Posted 16 January 2008 - 11:59 AM
you just select the cx-1.3 target like you select machine edition or plus target. then all features not supported by cx-1.3 are disabled.
simple ha?
#60 Berti Baker
Berti Baker
    Sparky
  • MrPLC Member
  • PipPipPip
  • 223 posts
    United Kingdom
Posted 17 January 2008 - 09:33 AM
That's really handy beacause you can't install 1.3 and 2.0 on the same computer. Now I can support old and new customers on the same laptop :clap:
Bertie
Download » CX-Supervisor
    No categories found.
Store » CX-Supervisor
Articles » CX-Supervisor
