PID Instruction
  • Please log in to reply
6 replies to this topic
#1 lchamarthi
lchamarthi
    Sparky
  • MrPLC Member
  • PipPipPip
  • 156 posts
  • Interests:Automation in Omron, Reading and listening to Music
  • Country:India
    India
Posted 07 July 2006 - 01:06 AM
Hello All,
Could anybody give quick help in PID instruction..?
PID(190)
Source value: B35
Control Word: C:DE4
C+1:64-----P
C+2:100----I
C+3:190---D
C+4: 30--Time
C+5: I kept 1000.....But really didn't understand what it is from manual..?
C+6: Kept 404......This also i didn't understand from manual waht it is doing?
With the above settings i didn't see any result in the output word.
I am using CJ1M-CPU13 & DA041 Module to take 0---FA0 as resolution
Please help me quick....
Thanks in advance
lchamarthi
#2 alberto05
alberto05
    Sparky
  • MrPLC Member
  • PipPipPip
  • 41 posts
  • Country:Spain
    Spain
Posted 07 July 2006 - 06:33 AM
[quote name='lchamarthi' date='Jul 7 2006, 08:06 AM' post='36513']
Hello All,
PID(190)
Source value: B35
Control Word: C:DE4
C+1:64-----P
C+2:100----I
C+3:190---D
C+4: 30--Time
hi,
The PID function is rellally strange, try with this values:
c+5:#0002
c+6:#1494 (there is an error in manual w340-e1-06 (seite 666, bits 04 to 07 of c+6, bits 00 to 03 of c+6, column 1, files 4 and 5), must be 4-->5 and 5-->4
c+4:put &0100
c+3:put &0000
c+2:put &9999
c+1:play with this, for example&0010 (c+1 is not P constant, is the proportional band (BP=100/P)
so, if you have: source &0002
control &0005
then error is 3, with a BP=100, P=1, so output must be &0003, if BP=50 ---output:&0006
the integer factor is, for example, if sampling period is &0100(1s, units in 10ms), and c+3=&0003, then, with the same source and control, you will have 3,6, 9,12,..., each second add 3 to the output.
sorry, i have not more time.
hope this help you, i am not sure how the pid works but.... For example, if the source change very fast ( an input step), the pid take a time to actuate (they call it overshooting prevention)
#3 lchamarthi
lchamarthi
    Sparky
  • MrPLC Member
  • PipPipPip
  • 156 posts
  • Country:India
    India
Posted 09 July 2006 - 12:32 PM
Hello All,
I have implemented one PID instruction in the attached code. In the result word always it is giving &4095 constantly regardless of what ever the set value. My expectation i think it should give zero when the Process value is more than Set value.
I couldn't able to find what i am doing mistake in this. Can anybody help me out quickly in solving this.
Becuase I have to submit this project by tomarrow morning. I will be very thankful to them.
Please find the attached code.
Thanks in advance.....& hope to get reply.
Lchamarthi
#4 Bill Estey
Bill Estey
    Sparky
  • MrPLC Member
  • PipPipPip
  • 29 posts
  • Country:United States
    United States
Posted 10 July 2006 - 12:00 PM
[quote name='alberto05' date='Jul 7 2006, 07:33 AM' post='36517']
Hello All,
PID(190)
Source value: B35
Control Word: C:DE4
C+1:64-----P
C+2:100----I
C+3:190---D
C+4: 30--Time
hi,
c+5:#0002
c+4:put &0100
c+3:put &0000
c+2:put &9999
control &0005
[/quote]
Try these settings:
c+1 2000 (P)
c+2 10 (I)
c+3 10 (D)
c+4 100 sampling time)
c+5 0000 (Forward acting control)
c+6 1818 (Limit control-16 biti nput-sampling period-16 bit output)
c+7 0 (low output value)=0
c+8 0FFF (high output value)=4095
Good Luck
#5 alberto05
alberto05
    Sparky
  • MrPLC Member
  • PipPipPip
  • 41 posts
  • Country:Spain
    Spain
Posted 11 July 2006 - 01:50 AM
[quote name='Bill Estey' date='Jul 10 2006, 07:00 PM' post='36631']
Hello All,
PID(190)
Source value: B35
Control Word: C:DE4
C+1:64-----P
C+2:100----I
C+3:190---D
C+4: 30--Time
hi,
c+5:#0002
c+4:put &0100
c+3:put &0000
c+2:put &9999
control &0005
[/quote]
Try these settings:
c+1 2000 (P)
c+2 10 (I)
c+3 10 (D)
Good Luck
[/quote]
hi,
here is an example of PID configuration based on your program. Downoad the D memory area too
it is an error in my first reply, BP is in omron 999,9%, so you must multiply by 10 waht i said before.
play with diferent bp, i and d constant and try to understand how it works. First try with i=9999 and d=0000, ie no i and d action
hope this helps.
#6 lchamarthi
lchamarthi
    Sparky
  • MrPLC Member
  • PipPipPip
  • 156 posts
  • Country:India
    India
Posted 17 July 2006 - 08:33 AM
Hi All,
I am struggling with PID with different problems since from the starting. Atlast I achievied the PID action but still my problem is not solved.
In One PID Loop, Max Result is coming &4095
In another PID loop, Max Result is going to &255 as attached in the snap shots. Both are giving good PID action.
I Couldn't able to find the reason. I kept the C to C+10 Parameters same for both. Just bit observaion in one PID process i observed #FFF and in another one #FF in after C+10 words.
Could anybody help me in achieving this?
Thanks in advance
Lakshmi
Edited by lchamarthi, 17 July 2006 - 08:37 AM.
#7 Bill Estey
Bill Estey
    Sparky
  • MrPLC Member
  • PipPipPip
  • 29 posts
    United States
Posted 17 July 2006 - 01:16 PM
[quote name='alberto05' date='Jul 11 2006, 02:50 AM' post='36659']
Hello All,
PID(190)
Source value: B35
Control Word: C:DE4
C+1:64-----P
C+2:100----I
C+3:190---D
C+4: 30--Time
hi,
c+5:#0002
c+4:put &0100
c+3:put &0000
c+2:put &9999
control &0005
[/quote]
Try these settings:
c+1 2000 (P)
c+2 10 (I)
c+3 10 (D)
Good Luck
[/quote]
hi,
hope this helps.
[/quote]
