Peripheral port - printer
  • Please log in to reply
6 replies to this topic
#1 beljic
beljic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 30 posts
  • Country:Yugoslavia
    Yugoslavia
Posted 10 May 2006 - 03:36 PM
Is it posible to connect serial printer (Epson LX-300) and CJ1M PLC (using peripheral port)? I want to print data from DM area using TXD instruction.
#2 Nibroc
Nibroc
    Sparky
  • MrPLC Member
  • PipPipPip
  • 454 posts
  • Country:New Zealand
    New Zealand
Posted 11 May 2006 - 01:16 AM
Beljic,
The CJ1M does not support 'no protocol' mode via the peripheral port, you will be unable to use the TXD command with this port.
You can however use the RS232 port. (is this port free ?)
Nibroc
#3 beljic
beljic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 30 posts
    Yugoslavia
Posted 11 May 2006 - 04:24 AM
Thank you Nibroc.
RS232 port is not free. Can you tell me what is the best (and not expensive) serial com. unit for CJ1M?
#4 gtsuport
gtsuport
    Omron Disty
  • MrPLC Member
  • PipPipPipPipPip
  • 884 posts
  • Interests:Omron Distributor Tech Support, 4-H Volunteer
  • Country:United States
    United States
Posted 11 May 2006 - 06:27 AM
If the CJ1M is a Version 3 processor you can use a CJ1W-SCU21-V1 Serial Communication module and use the TXDU instruction. This will give you 2 RS-232 ports.
If it is an older processor, you can still use the same module, you will just need to set up a protocol macro and use the PMCR instruction, which will require CX-Protocol software.
Hope this will help.
#5 beljic
beljic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 30 posts
    Yugoslavia
Posted 11 May 2006 - 06:52 AM
Thank you!
Yes, it is Version 3 processor. Is this configuration posible?
NT3S touch panel connected to RS232 port on PLC (PORT)
Epson LX300 connected to CJ1W-SCU21-V1
Other CJ1M connected to CJ1W-SCU21-V1
#6 gtsuport
gtsuport
    Omron Disty
  • MrPLC Member
  • PipPipPipPipPip
  • 884 posts
    United States
Posted 11 May 2006 - 07:15 AM
The above configuration depends on how you want to communicate with the other CJ1M processor. If you want to use the Serial PLC Link, that will require using the Built In RS232 port.
You would be able to move the NT3S to a port on the CJ1W-SCU21-V1 without a problem.
You could also use the CJ1W-SCU21-V1 and the TXDU instruction to send data to the Epson printer.
#7 beljic
beljic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 30 posts
    Yugoslavia
Posted 11 May 2006 - 08:28 AM
I will connect touch panel and printer to CJ1W-SCU21-V1 and other cj1m to cpu port.
Thank you alot.
