Forums.MrPLC.com: Security in RSVIew32 - Forums.MrPLC.com
This Month's Allen Bradley Forum is:
Sponsored by PDF Supply - PDF Supply sells New and Remanufactured GE Fanuc and Allen-Bradley PLC's
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Security in RSVIew32 how to? Rate Topic: -----
#1
User is offline   damenace
  • Hi, I am New!
  • Pip
  • Group: MrPLC Member
  • Country:Bulgaria
    Bulgaria
Good evening!
Only recently I've decided to implement a security to one of my RSView32 projects.
After going through a number of AB user guides all I could come up with was the following:
"The first step in setting up security is assigning security codes. You can limit
access to any RSView32 command, graphic display, or tag by assigning a
security code to it. There are 17 codes—an asterisk (*) and the letters A through
P. The asterisk allows unlimited access, and the letters limit access.
Once you have assigned the security codes, you can then assign the codes to
users or groups of users. In this way, you can limit users’ ability to run
commands, open displays, and write to tags. Use the User Accounts editor to
assign security codes to users.
When adding users to RSView32, you can enter user names and passwords in
the User Accounts editor, or, if you are using Windows Vista, Windows Server
2003, Windows XP or Windows 2000, you can use the Windows user list
instead of creating a custom list in RSView32. No matter which method you
use, you still have to assign security access to the individual users."
I have then assigned a letter to the tags and displays I wish to remain invisible for other users but I have a problem when I try to create different user profiles in User Account Editor and make the program display a message on login to pick from that user list.
Can anyone who has been through that process guide me step by step through it?
0
#2
  • Hi, I am New!
  • Pip
  • Country:Bulgaria
    Bulgaria
Any feedback will be appreciated :)
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
