analog scaling problems
  • Please log in to reply
4 replies to this topic
#1 sparkotronic
sparkotronic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 100 posts
  • Gender:Male
  • Interests:Music, Music, Music and the occasional book. Often at the same time.
  • Country:Scotland
    Scotland
Posted 20 November 2009 - 04:13 PM
Hi
I'm trying to change a project in my workplace.
I need to replace an existing analog input card with an analog in/output card on a Siemens S300 PLC.
The problem is that the input signal is 4-20mA but the I/O card reads 0-20mA.
Does anyone have any idea of some code that will turn the 0-20 into 4-20 so that I can integrate it into the original program?
Thanks in advance, Colin
#2 slcman
slcman
    Sparky
  • MrPLC Member
  • PipPipPip
  • 341 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 22 November 2009 - 10:14 AM
You may use FC105 in standard library -> TI-S7 Converting block
For see library, clic in menu bar View -> Overview
SLCMAN
#3 sparkotronic
sparkotronic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 100 posts
  • Gender:Male
  • Country:Scotland
    Scotland
Posted 22 November 2009 - 02:26 PM
I did think about that, but the result of FC105 is in real form.
To integrate it into the original program, I need it to be in integer format as the program has a custom built scaling block which turns 4-20mA into Degrees celcius.
Someone suggested FB450, I've been told that this is a Siemens standard block for converting 0-20mA into 4-20mA and FB451 is to go the other way.
#4 JesperMP
JesperMP
    Guru
  • MrPLC Member
  • PipPipPipPipPip
  • 784 posts
  • Country:Denmark
    Denmark
Posted 23 November 2009 - 10:06 AM
Hi Colin
FC105 SCALE is recommendable.
The FC105 assums that the native analog range of the input module is used.
You can easily trick FC105 to account for the difference between 4-20mA and 0-20mA, by changing the minimum scaled value by minus 25% of the full range.
Example: 4-20mA = 0-100 degr.C --> FC105 minimum = -25 degr. C
To change to an Integer, use the RND function.
Be sure that the INT value can span the converted REAL value.
Simple example:
L "rVal"
RND
T "iVal"
edit: You can probably use the same principle of offsetting the minimum value with the custom scaling block.
Edited by JesperMP, 23 November 2009 - 10:06 AM.
#5 sparkotronic
sparkotronic
    Sparky
  • MrPLC Member
  • PipPipPip
  • 100 posts
  • Gender:Male
  • Country:Scotland
    Scotland
Posted 25 November 2009 - 12:27 AM
Hi Colin
Simple example:
L "rVal"
RND
T "iVal"
Thanks for the reply.
A very nice person on another forum gave me a bit of code that works great with the exsisting scaling block.
Thanks for the help, I'd be lost without the internet and all you great folks!
