IPB
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
Looking for a Controllable PSU
andyhill
post Nov 4 2009, 02:06 AM
Post #1
Newbie
Group: MrPLC Member
Country:United Kingdom
United Kingdom
Just a quickie
Looking for a solution to provide a 0 - 30v DC Supply at up 3A. Problem is the control of the voltage 0-30 must be able to be proportionally controlled by a PLC either digitally or vai analog control(4-20mA or 0-10v etc) . If possible, I would like and off the shelf solution that could be DIN rail mounted. PLC will typically be a Compact logixs.
Application is for a test rig to allow us to ramp up and down the voltage in 1/2 volt steps. However load is approximately 2A at 24v DC.
Go to the top of the page
+Quote Post
milldrone
post Nov 4 2009, 02:49 PM
Post #2
Sparky
Group: MrPLC Member
Andy,
Not exactly what your asking for. The DIN mentioned is a DIN plugin for a porportional valve coil.(hydraulic)
http://www.pwmcontrols.com/
+Quote Post
pfort
post Nov 4 2009, 06:00 PM
Post #3
Sparky
Group: MrPLC Member
Country:Canada
Canada
QUOTE (andyhill @ Nov 4 2009, 02:06 AM) *
Just a quickie
Just an idea, but: did you consider a DC motor drive?
Ex.: KBIC120 from KB. 0-10V analog output to it would give you about 0-100VDC.
+Quote Post
andybr
post Nov 5 2009, 12:09 PM
Post #4
Sparky
Group: MrPLC Member
Country:England
England
Andy.
As you are in the UK I would suggest you speak to Lambda who are based in Ilfracombe. I am sure that they will be able to do something off the shelf which meets your requirements.
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
RSS Lo-Fi Version Time is now: 20th November 2009 - 09:28 PM
