GSV help!
  • Please log in to reply
2 replies to this topic
#1 damper
damper
    Sparky
  • MrPLC Member
  • PipPipPip
  • 16 posts
  • Country:United States
    United States
Posted 18 March 2009 - 04:48 AM
I need some advice on the GSV instruction in RSLogix 5000. I’m designing a project that is going to have a FlexLogix processor and a remote 1794-AENT ethernet adaptor. Evidently I need to ‘talk’ with the remote chassis all times but, I do not want a major fault is I do not have communication with it, so I disabled that option in the ‘Module Properties’ screen. Is it possible to use a GSV instruction to see if the communication between the processor and the adaptor is in a ‘true’ or ‘false’ state? The goal I’m trying to accomplish is to display an alarm on the HMI to notify that it needs attention, but ‘keep on trucking”.
Also, please tell me if this is correct. I’ve used a GSV instruction to pull the battery status (Class Name: FAULTLOG, Attribute Name: MinorFaultBits, Dest: X). I’ve use a DINT tag for X. In series is the GSV, XIC (X.[10]) and an boolean OTE. So, if the battery goes low, would this make my OTE energized?
#2 lccllc
lccllc
    Sparky
  • MrPLC Member
  • PipPipPip
  • 55 posts
    United States
Posted 18 March 2009 - 07:23 AM
See pub 1794-rm001_enp.p chapter 2, in the GSV use Class Module instance the (name of the adapter) Attribute Fault Code. Also read the fault codes from the adapters manual.
" Ok i am a nerd'
#3 Ken Moore
Ken Moore
    Principal Specialist
  • MrPLC Admin
  • 1711 posts
  • Gender:Male
    United States
Posted 18 March 2009 - 09:26 AM
I need some advice on the GSV instruction in RSLogix 5000. I'm designing a project that is going to have a FlexLogix processor and a remote 1794-AENT ethernet adaptor. Evidently I need to 'talk' with the remote chassis all times but, I do not want a major fault is I do not have communication with it, so I disabled that option in the 'Module Properties' screen. Is it possible to use a GSV instruction to see if the communication between the processor and the adaptor is in a 'true' or 'false' state? The goal I'm trying to accomplish is to display an alarm on the HMI to notify that it needs attention, but 'keep on trucking".
Also, please tell me if this is correct. I've used a GSV instruction to pull the battery status (Class Name: FAULTLOG, Attribute Name: MinorFaultBits, Dest: X). I've use a DINT tag for X. In series is the GSV, XIC (X.[10]) and an boolean OTE. So, if the battery goes low, would this make my OTE energized?
Yes your battery status should work; here is a screen shot from a L-61 program:
THOXSIS_MinorFltWord is a DINT
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
