LS Master-K120 PLC - Cnet Communication
  • Please log in to reply
2 replies to this topic
#1 Walter Kurtz
Walter Kurtz
    Hi, I am New!
  • MrPLC Member
  • Pip
  • 1 posts
  • Country:United States
    United States
Posted 17 March 2009 - 08:58 PM
I am working with an LS Master-K120 PLC.
I have managed to write a simple program and download it to the PLC.
This was done using RS-232 and COM1.
Now I am trying to connect using an OPC server. I happen to be using KepServer.
Following the PLC manual's instructions, I modified my serial cable and configured my parameters.
Then I added the device using KepServer, but could not connect.
I found a small application at the PLC manufacturer website called the Cnet frame editor.
I also failed to connect with this application. Only timeout errors.
I've checked and double checked my basic parameters (station number, baud rate, parity, data/stop bits). I've sent my question multiple times here (http://eng.lsis.biz/), but LS has not responded.
If I can figure out how to connect to the PLC using Cnet Frame Editor, I can move on. Until then I'm stuck.
I'm really banging my head. I hope someone here has worked with this PLC.
#2 Mark-
  • MrPLC Member
  • PipPipPip
  • 156 posts
  • Gender:Male
    United States
Posted 09 May 2009 - 10:30 AM
I am playing with this card G6L-CUEB at the present and looked at the frame editor.
When the switch is set to 3 and the defaults are used the card outputs:
02 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 03
02 50 4F 4E 4D 4C 4B 4A 49 48 47 46 45 44 43 42 41 03
over and over.
So, the default serial settings are 38400, 8N1.
It appears you can construct frames and send/receive to the card.
Doubling clicking on a frame brings up the editor.
The frames can be saved and loaded. I have not been able to find any pre-created frames.
I am adding support for the Master-K protocol to PeakHMI. I was unaware that Kepware supported Master-K. It is not listed on their website.
More investigations.
Good luck,
#3 TheTeck.Com
  • MrPLC Member
  • PipPipPip
  • 29 posts
  • Country:Syria
Posted 17 October 2010 - 05:27 AM
Please check the program in the link below:
Download » Other PLCs
    No categories found.
Store » Other PLCs
Articles » Other PLCs
