PLC
  • Please log in to reply
3 replies to this topic
#1 WKla
WKla
    Sparky
  • MrPLC Member
  • PipPipPip
  • 143 posts
  • Gender:Male
  • Country:Romania
    Romania
Posted 26 January 2009 - 01:15 AM
Hello.
Are there any PLC's that can operate in "extreme" temperatures, let's say -40(-30) +70(+75) C (-40 167 F) or near that temperature?
Thank you.
#2 panic mode
panic mode
    Mitsubishi Moderator
  • MrPLC Admin
  • 2171 posts
  • Gender:Male
  • Interests:many...
  • Country:Canada
    Canada
Posted 18 February 2009 - 10:26 PM
not sure what size plc we are talking about. you should have better luck with small ones like Siemens Logo! and specially SIPLUS version which is designed for outdoors installations and extended temperature range.
#3 motioncontroller
motioncontroller
    Sparky
  • MrPLC Member
  • PipPipPip
  • 20 posts
  • Gender:Male
  • Country:Canada
    Canada
Posted 04 July 2009 - 10:26 PM
I know your post was a while ago but I have been in Northern Alberta and the middle of Wyoming cold starting 9030's at -45 degrees. I have also been working in Mexico with the same racks/configs when the air con broke in the building and the systems still worked fine ambient was 100 degrees on average plus electric components in the cabinets must have had temp in cabinets quite high. I have always had problems with moisture control vs temp control with GE Fanuc products.
Cheers
#4 RussB
RussB
    Expert
  • MrPLC Member
  • PipPipPipPip
  • 541 posts
  • Gender:Male
  • Country:United States
    United States
Posted 08 July 2009 - 10:42 PM
Cheers
If you purchase the "Conformal Coated" products from GE Fanuc you will not have moisture problems, they also have "extended temperature" products available in nearly all module types. The 90-30 has been around since 1990 and has a lot of options and ruggedness. You can check it out at www.gefanuc.com/support
Russ <))>(
LEARN something today so you can TEACH something tomorrow.
DETAIL in your question, promotes DETAIL in my answer.
Do you "Believe"? Do you vote? Please Read:
