Forums.MrPLC.com: Program Using the PLC Real-Time Clock - Forums.MrPLC.com
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Program Using the PLC Real-Time Clock In Need of Some Help Programming Rate Topic: -----
#1
User is offline   MikeSparks
  • Newbie
  • PipPip
  • Group: MrPLC Member
  • Country:United States
    United States
Hello All -
First time posting here, please allow some leniency if I'm not posting correctly...
It's been many years since I've programmed so I'm a bit rusty.
I have a SLC500 and use RSLogix500 to program the ladder logic.
I have a FactoryTalk View ME application were I'm using the ActiveX MEDataStorePlus control to capture process data from my SLC500. My goal is to send process data from the SLC500 to a .csv file at certain times (before the end of a shift), using FactoryTalk. The problem is the MEDataStorePlus control uses a trigger to activate the data collection. What I believe I need to do is write some code in the ladder logic to look at the real-time clock in the PLC. Once the PLC real-time clock equals 6:45 am, 2:45 pm and 10:45 pm respectively, I will set a bit in the PLC that is picked up through my FactoryTalk View ME application and thus sets the trigger for the MEDataStorePlus, collecting my process data.
Quite frankly I'm a bit rusty at programming and the scenario I explained is a bit over my head.
Does anyone have any suggestions to get me going or perhaps were I could view sample code using the SLC500 real-time clock in a ladder program? It appears the system or status bits I would be looking at our S40 (HH) and S41 (MM).
Best Regards,
Mike
0
#2
User is offline   TConnolly
  • Guru
  • PipPipPipPipPip
  • Gender:Male
    United States
View PostMikeSparks, on Aug 29 2008, 12:03 PM, said:
Hello All -
Best Regards,
Mike
Greetings Mike, and welcome to the forum.
Paste the following into an empty rung in an empty program. Insert a new rung, double click the rung number to the lef of the rung, and paste this text into the mnemonic field that opens.
EQU S:40 6 EQU S:41 45 OSR B3:0/0 OTE B3:0/1
This rung shows how to set a trigger at 6:45 am. In this example the trigger will last for just one scan because of the one-shot. Hopefully its enough to get you started.
0
#3
  • Newbie
  • PipPip
    United States
Hello All -
Best Regards,
Mike
Yes, that will get me started.
Thanks for your help Alaric.
Have a good one,
Mike
0
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
