RSlinx Lite and RSLogix 500 starter FREE
If you are looking for the FREE version of Allen Bradley RSLogix 500 and the free version of RSLinx lite then use this, this was wrote by me so there may be an error or two but it should help you get what you are after
Go to HERE
Now click on software up dates and agree to the terms
You must register if you don't have an account, then enter your login name and password
Click on the hyperlink "Select by Catalog Number" for RSLogix 500 starter (this is for 10 point AB PLC's only) use part number 9324RL0050ENE… for RSLinx 'Lite' use this part number 9355WAB100ENE
Enter the part number and click apply, click on the file below your user name and click qualify for update and choose "Download all files"
You will have to do this once for each file, Linx and Logix
Note: RSLinx lite will work with more then just RSLogix starter
After you download the file then unzip the file and install the software, when you are asked for a serial number, use 0123456789
RSLogix 500 is a normal size and can be downloaded at any time, but RSLinx is a very large file and you may want to down load this late at night, you will need the entire file.
Now… RSLogix 500 Starter, will only work with one type of PLC, that is the 10 point Allen Bradley PLC, this model number is 1761-L10BWB and 1761-L10BXB I have verified it on BXB but not on the BWB and I also think it will work on the 1761-L10BWA, the BXB has transistor outputs the BWB has relay outputs, you can get more information at HERE
Also this software will not work with all 10pts, I know that some of the older PLCs (firmware) it will not, so this needs to be a new or newer PLC, if I ever find out the exact ones that is will or will not work with I will post them.
Hope this helps....
This post has been edited by geniusintraining: 24 September 2007 - 06:22 AM
Sign In »
Register Now!
Help
Back to top
