wbb
ab ach file
8 posts in this topic
can you open a ach file and view it? the rs logix will not open the file. thanks
The *.ACH file extension was used for several different A-B programming packages for the SLC-500 an various PLC-2/3/5 families. RSLogix 500 will open *.ACH files that were created by APS programming software for SLC's, for example. Which edition of RSLogix (500, 5, 5000 ?) are you using, and do you konw which type of controller the program is for ?
Post it here. And someone will try to open it. Then try to convert to a .RSS or print to a PDF file
i would, but i can not open it at all. the computer sees it, states how large a file it is, how many rungs, instructions and so forth, but it will not open.
No need to open it just post the ?.ACH file might have to zip first. Edited by Mickey
also ... if you have any other files with the same FIRST NAME as your .ach file, it would be a good idea to post them too ... the older software (pre-RSLogix) used separate files for documentation and other comments ... we'll try to merge those for you if you'll send them along ...
*.ACH file is created if you emulate your RSlogix 500 program, You can open the program but No Discreption and Symbol would go. Try to open again your Program with *.RSS extention then save Us, *.ACH. then re open again, am' sure it will open. Gnex
