Control Net Scanner
  • Please log in to reply
23 replies to this topic
#1 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 26 April 2007 - 11:01 AM
Hi all,
I am new with Control Logix and Control Net. I have a project with a Logix 5561, a control net scanner, 1756-CNB/D and a Control Net adapter in a PLC5 rack (1771-ACN15 I/O adapter).
Could anybody to help me how to configure the communications, please?
The error at the I/O adapter is: Connection not scheduled. I have tried to configure it with ControlNetworks for CN, but I haven't had any luck.
Thanks,
Mushu
#2 Ken Moore
Ken Moore
    Principal Specialist
  • MrPLC Admin
  • 1711 posts
  • Gender:Male
  • Country:United States
    United States
Posted 26 April 2007 - 04:46 PM
I've never used that software. But, typically you upload the devices on the network, set your parameters and the save. Are you sure of your wiring and connections, resistors, etc....?
#3 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 26 April 2007 - 05:49 PM
Download program to the Controller - I am assuming that you already did it
Start RSnetworx for CNET:
- File->NEW
- Upload from the network
- Enable Edits
- Set UMAX, SMAX and NUT
- File->Save As-> Optimize and Re-write
#4 BobLfoot
BobLfoot
    The Wizard
  • MrPLC Admin
  • 3175 posts
  • Gender:Male
    United States
Posted 26 April 2007 - 10:25 PM
Some Questions - Best handled in order
1. Does your 1756-CNB/D show in the IO Tree of your RS5000 Project?
If not you need to add it.
2. Does your 1771-ACN15 show in the IO Tree of your RS5000 Project?
3. Have you tried Contr_Conn's instructions for RSNetworx and are you still getting an error?
If so please post it and if possible your *.ACD and *.CNT files.
BobLfoot
"Poor Planning on your part does not a crisis on my part make"
#5 rpraveenkum
rpraveenkum
    Project Lead - Controls
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Interests:PLC....PLC.....PLC
  • Country:India
    India
Posted 26 April 2007 - 11:59 PM
use this manual
http://literature.ro...gr001_-en-e.pdf
PRAVEEN KUMAR
http://www.praveen.envy.nu
Life is like butterfly, handle with care - Praveen
#6 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 01 May 2007 - 04:34 AM
Thank you all for your answers.
Contr_Conn, I follow your instructions, and I had already the modules in the I/O configuration as BobLfoot indicated (I was trying to find the Contr_Conn's instructions for RSNetworx, jajaja, until I realize Contr_Conn it was your nickname, not some RSLogix or RSNetworx function, :-2 )
And I have still the same error.
Please find attached my ControlNet and Control Logix files.
Rpraveenkom, I can't open the link that you put.
Thanks,
Mushu
#7 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 01 May 2007 - 05:10 AM
have you downloaded the rsnetworx file to the scanner ?
use this link http://literature.ro...gr001_-en-e.pdf
PRAVEEN KUMAR
#8 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 01 May 2007 - 06:05 AM
Hi all again,
I am trying to use the Scanlist Configuration Tool, but it is disable (in grey) and I don't know how to get it.
Any idea?
thanks,
Mushu
#9 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 01 May 2007 - 06:09 AM
It is used only for the PLC5 controlnet processors rsl5k should be used for the configuration
can post the full configuration of the system?
PRAVEEN KUMAR
#10 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 01 May 2007 - 06:15 AM
Hi Rpraveenkum,
Thanks for your help; I attached the two files two post ago, if you can't download them let me know and I try to find another way.
#11 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 01 May 2007 - 06:24 AM
Configuration of the modules, rack size, & placement of each module in the 1771-ACNR rack details required.
PRAVEEN KUMAR
#12 Contr_Conn
Contr_Conn
    Sparky
  • MrPLC Member
  • PipPipPip
  • 426 posts
    United States
Posted 01 May 2007 - 06:48 AM
With controllogix you should not touch scan list tool in RSnetworks.
Just follow instructions I posted above - this is all you need to do to get rid of eroor 16#0317 - connection not scheduled.
#13 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 01 May 2007 - 06:51 AM
CNet config Clx is not added in Clx chasis
Better open new rsnetworx file Browse the devices online save it & download it to the Network
Most of the problem will be solved by this method
PRAVEEN KUMAR
#14 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 02 May 2007 - 05:55 AM
Hi all,
I tryed several times what Contr_Conn suggested and now that problem is solved, but another error has appeared, :-2
the error is:
16#0109 Connection Request Error: Invalid connection size
Note: Additional Error Information for this fault will be displayed as the tag name associated with the connection instance number that has the fault.
The controller is attempting to set up a connection with the module and cannot the size of the connection is invalid. The controller may be attempting to connect to a tag in a producing controller whose size does not match the tag in this controller.
Electronic Key Passed fault
If the module is a 1756-CNB or 1756-CNBR adapter, ensure that the chassis size is correct.
For RIO Adapters, ensure that the rack size and/or rack density is correct.
I am trying to read the data with the COP instruction, and then I call my tagname PLC5_CPU:I, datatype: AB:1771_ACN15_40Bytes:I:0.
The I/O adapater is in a five slot PLC5 rack;
Please find attached my new Control Net file.
Thanks,
Mushu
#15 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 02 May 2007 - 06:12 AM
If you are using 1771 -A1B in 1/2 slot addressing
select the Properties of the 1771 ACNR change the Input size & output size to 8
If you are using 1771 -A1B in 1 slot addressing
select the Properties of the 1771 ACNR change the Input size & output size to 4
PRAVEEN KUMAR
#16 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 02 May 2007 - 06:40 AM
Hi Rpraveenkum,
I am reading the user manual for the ControlNet Adapter module (1771-ACN15), and I don't really understand. I am lost with the slot addressing and the Processor Memory Rack.
in one PLC 5 rack I have:
1. 1771-ACN15
2. Power supply
3. Spare
4. 1771-IBDB (16DI)
5. 1771-OAD (16DO)
in the other PLC 5 rack I have:
1. 1771-ACN15
2. Power supply
3. Spare
4. 1771-IFE (8AI)
5. Spare
How could I access to the information?
I don't know (understand) the differences between 2, 1 and 1/2 slot addressing. :-2
Thanks again,
Mushu
#17 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 02 May 2007 - 06:55 AM
Use this manual
http://literature.ro...um124_-en-p.pdf
In Chapter 3 you can know about the slot addressing
See the dip setting for actual slot addressing
PRAVEEN KUMAR
#18 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 02 May 2007 - 07:06 AM
Hi Rpraveenkum,
that is the manual I am reading, but I don't really understand the addressing, :-2
I don't see the dip setting; the cards are narrow (only one slot is used); they won't be my final cards, I am using them for training only, as I don't have the final cards.
Thanks,
Mushu
#19 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 02 May 2007 - 07:20 AM
To access the Dip switches power down the rack remove ACN15 you can see the dip switches
PRAVEEN KUMAR
#20 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 02 May 2007 - 09:15 AM
the slot addressing is 1 (5=On, 6=Off)
#21 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 02 May 2007 - 10:45 AM
Problem solved, thank you very much :-2
I was considering that I had the cards on slots 1 and 2, but in fact they are in 2 and 3, as the power supply is consider a slot as well.
Thanks again.
#22 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 03 May 2007 - 07:12 AM
I am here again, :-1
I have as well an analog card, 1771-IFE
How could I read this channels?
I have their user manual, and Block transfers are needed (39 Out words and 20 or 22 In words), but I don't know how to use them with the controlnet.
Any idea?
#23 rpraveenkum
rpraveenkum
  • MrPLC Member
  • PipPipPipPip
  • 678 posts
  • Country:India
    India
Posted 03 May 2007 - 07:20 AM
see this tech note
http://rockwellautom...amp;p_topview=1
PRAVEEN KUMAR
#24 Mushu
Mushu
    Sparky
  • MrPLC Member
  • PipPipPip
  • 47 posts
  • Country:Ireland
    Ireland
Posted 03 May 2007 - 10:05 AM
Problem solved.
