atoy
GT01-C10R4-8P and lamps not shown on GT1565vtba
3 posts in this topic
hi all, i searched on the net that GT01-C10R4-8P can be used to communicate FX3U 32MT-ES/A and GT1565vtba hmi. is it working? also ive made a monitor to be downloaded to the GT1565vtba but after downloading it the lamps did not show on the GOT. please help. thank you.
If there is no communication they will not show. Look at the GOT1000 Connection manual for proper cables. It's all in the manual.
GOT1000_-_Connection_Manual_(FX3U_Ethernet)_SH(NA)-080719-B_(10.08).pdf The link shows you a video how to set up an GOT/FX3U PLC communication trough an Ethernet connection. Be sure to set the IP range properly. I suggest you programm the GOT wit IQ-Works software. To make a simple test: Place a light (lamp) on the screen from the library and set as a trigger M8013. If your communication is working properly the light should blink in a 1 second sequence. I attached the MIT manual but I'm not sure if this went wel (not experienced with attachments in this forum) Have a good day, Theo V.
