ChrisBarrett
Calculate Flow Using Pluse Input
Hello again guys! Once again I would like to pick your brains. I have a flow meter that sends a pulse for every cubic meter of liquid. The frequency of the flow meter specs at 50Hz so an input to a CP1H PLC should work. I was wondering if any of you guys have a function block or a piece of code written to obtain instantaneous flow. Thanks in advance!! Cheers Chris
50hz would be 50 cubic meters per second?? Are you sure you have those numbers right?? That's a LOT of liquid!
Opps...sorry, I should have made myself more clear. The flow meter has a MAX frequency of 50 Hz....HA!! Yup, 50 cubic meters of liquid a sec sure is a lot.....HA! Chris
The actual pulse rate will determine the best approach (particularly for low flow rates), but here's a couple of ideas: 1) Use a high speed counter to capture the number of pulses. 2) Create a scheduled task that runs periodically to handle the data collection. 3) Read the pulse count using a PRV instruction. 4) Average the pulse counts using an AVG instruction (see notes). 5) Convert the average pulses to flow in GPM or LPM and store in a DM register. Averaging notes: 1) The AVG instruction resets itself if the control line cycles so it needs to be "always on". 2) Use the scheduled task timing to control how often the data is averaged. 3) For low counts multiply the pulse count by 100 before averaging to improve the resolution. Flow_Monitor.pdf
Thank you so much for the advice and instruction. I will give it a go and let you know how it works out!! Cheers Chris
For CP1H PLCs the PRV instruction can return the Frequency of high speed counter 0. Therefore you would not need to do anything else (averaging, sampling, etc) if you use the PRV instruction in that manner.
