Posted 3 Apr 2014 I've created a key window with a sub-set of the ASCII characters. Can I switch between the user-created key window and the default or another custom key window? Can this be done depending on which base screen is visible, what variable I am changing, or via the PLC program? The manual refers me to sections 2.8 and 2.9 of the functions manual but I can't find the relevant information. I've downloaded a couple of sample applications. These use user-created key windows but do not switch between different ones. I've set Environmental settings -> key window -> basic settings 1st Window Screen number for ASCII = 5 number of screens used for ASCII = 2 I can only use the custom screen and suspect that the choice is default or custom with no way to switch between the two. Can anyone help? Share this post Link to post Share on other sites
Posted 3 Apr 2014 I believe you can go into the individual screen properties and select to prioritize the key window for that screen over the project setting. See attached pic. I hope this helps, Dave Share this post Link to post Share on other sites
