medensat
feedback
3 posts in this topic
Hello, i'm working on a project in what I control a motor, the problem is that when I send the command starting the motor i need feedback that will inform me that the motor is in working order, and before starting I need to know there is no power cut. i need u r help to make the corresponding ladder program. i program with GX IEC DEVELOPER 7.04 note: PLC:mitsubishi FX thanks in advance
Can you explain more about your connection. Are you starting the motor with a digital or via a protocol (to an inverter) to start the motor? Which signals do you send and receive to/from the motor. How does the motor or inverter respond when you start the motor? Do you get an active signal back?
http://forums.mrplc.com/index.php?showtopic=29016
