rudalboy09
VB6 to CJ1G with ETN21
4 posts in this topic
i have a problem with my project study. i can connect it, with ping it in cmd. i use UDP protocol. my computer's ip is 192.168.10.1 and plc's ip is 192.168.10.10 what i must configuration it with winsock? is there a configuration in CX-Programmer? or what? i just want to read and write data memory in D10, how i can send data in winsock? i can't understand "FINS Commands" if i can it, i will improve it in my program. anyone can help me? Thank you. Erwin Harry N
Sorry, i am newbie with this communication between PLC and PC with VB6. Before i use this application, and it works. http://forums.mrplc.com/index.php?app=downloads&showfile=705 Thank you.
You should download this VB.Net source code and see how it communicates with UDP then do the same in your application. http://forums.mrplc.com/index.php?app=downloads&showfile=992 Also, download the following pdf file for details on FINS command. http://forums.mrplc.com/index.php?app=downloads&showfile=620 These are the only 2 links you need to be a FINS expert.
