Posted 3 Mar 2015 What would the logic look like to delay an input? I have a prox switch about 1/2 a second upstream of a solenoid. When the prox senses a part I'd like the solenoid to start 1/2 a second later. When it stop sensing a part, I'd like the solenoid to stop 1/2 a second later. Share this post Link to post Share on other sites
Posted 3 Mar 2015 Welcome to the forum! To get any specific answers you'll need to provide some information on the type of PLC you're using and your software. But in a general sense, find the timer instruction for your PLC and read the help file on it. That should get you started. Share this post Link to post Share on other sites
Posted 3 Mar 2015 (edited) I'm using a 1300 with RSLogix 500. I have the following 3 timer commands available: TON; TOF; RTO. I appreciate you pointing out there are help files. I should have mentioned this earlier... this is the part that is giving me trouble. The gaps between parts are less than 1/2 a second. Therefore the off-delay timer will never count all the way up to 1/2 a second and thus never enable the 'Done' bit. While the off-delay or on-delay will delay 1/2 a second before coming on they will instantly go off once the prox changes state... no 1/2 off delay. Edited 3 Mar 2015 by danfman Share this post Link to post Share on other sites
Posted 3 Mar 2015 Will this work? Prox Gap |/|-----------------(L) Prox Part | |-----------------(L) Gap T1 | |-----------------|Pre=0.5sec| Part T2 | |-----------------|Pre=0.5sec| T2.DN Gap | |-----------------(U) T1.DN Part | |-----------------(U) Share this post Link to post Share on other sites
Posted 4 Mar 2015 Micrologix 1300? That's a new one to me... Your code looks like a really good start. Best way for you to learn is to actually have the hardware on your and try it out. Share this post Link to post Share on other sites
