klauricella
GX Works 2 usb driver for L CPU
6 posts in this topic
I am fairly new to Mitsubishi and starting up a new project. This is first time that I am trying to get online with a L02CPU PLC with my laptop that is running 64bit windows 7. When I try to go online it reconizes a device but will not load the usb driver. Is the driver hidden on the install disk someplace, I looked on the website but there is not one for the unit. Thanks Kevin
I don't have an L-CPU to test, but try updating the USB driver from: C:\MELSEC\Easysocket\USBDrivers
That is it Thanks. With my computer it was actual C:\Program Files (x86)\MELSOFT\Easysocket\USBDrivers Kevin
Great! Thanks for sharing the solution
I got a new PC with window 8.1; 64 bit; can't be communicated with FX PLC; it's USB driver problem; finally, found the manufacturer of USB driver is FTDI; so, choose FTDI, install the driver manually, problem solved.
Dino, this topic was about the L Series, not the FX. And FTDI is a driver commonly used with aftermarket USB cables. Mitsubishi does not offer a USB cable for FX.
