tantra
Need help CP1EN30 CIF41
3 posts in this topic
Need help. I'm newbie use CP1E and CIF41, may i can access CP1E with different IP? for example IP my CIF41 192.168.250.1 and IP other device 10.105.25.1 as iknow i can't setting gateway on CIF 41. may someone can help me? regard's Tantra
You would need a router to communicate between the two devices. Depending upon what your subnet masks are for your network, one portion of the IP Address is the network address, the other portion is the node address. To communicate with each other (without a router anyway), they need to have the same network address. See post #6 in the discussion below for a description of how the subnet mask defines which portion of the IP Address is the network and which is the node: http://forums.mrplc.com/index.php?showtopic=25148&hl=f3+error#entry121069
