Guest ImissAllenBradley
I need help with the temporary relay command
5 posts in this topic
I am converting old sysmac(dos) programs to CX prgrammer and I ran into an error upon comparison of the converted program. There seems to be a problem with the TRO command and it appears that CX will not accept this command, any hints???? Thanks for your time!! Edited by ImissAllenBradley
The TR registers are tempory registers - you should not have to put them into the new logic........
Are you converting the SSS code manually or are you using the CX Programmer File conversion tool?
I am using the conversion tool, if they are now not needed, can i not just take them out. Thanks for your help!!
No,maybe... you cannot ignore the need for temporary relays due to the original construction of your SSS code. Please describe the condition of your converted program. Does CX Programmer fail to show any rung as drawn ladder? Are there any rungs that show as Statement List? Post a screenshot if you can.
