jerrycat
Communication Format D8120
2 posts in this topic
i have set up a RS485 network between 7 FX serie's PLC using the FX485 ADP. i have used the two pair wiring method to hookup the PLC to each other These PLC and connected to a citect Scada system on a PC. What should the communication format be in the D8120 to properly commmunicate with Citect Scada
You don't say how the PLCs are connected to the PC. You should be able to use the default settings for comm if you are using the built-in serial port and an SC09 to connect the PC. If your PC is connected to the RS485 network, make it's port settings match the settings for your RS485 network you already configured.
