tmu
SPD
3 posts in this topic
Hi, anyone used SPD_M -command with GX-IEC 6.10 and FX2N? I got error msg C2017: Type mismatch on output variable. I have tried to type my code just like in example and I have used direct addresses. Tmu
tmu, The output from this block uses three integer variables. Therefore you have to declare an array variable of int (0..2). Then insert the label for the variable into the output of the function block.
Thanks waynes, now it works much better. Tmu
