Sergei Troizky
Simple programming cable for Mitsubishi FX
126 posts in this topic
Please  I want wiring diagram for cable between pc and plc melsec  FX32MT
I'm used melsec program software
Read the post you just replied to.  It's all about building the cables.
Dear sir
       Please send me the wiring diagram between pc  (dp 9 )and plc melsec FX32MT  (25 pin soket  ) and the suitable program software used.
Open your eyes and read the complete post....everything you need is there.
Gx developer will program it
Dear sir
      Thank you for interest. but I don't receive any post for drawing the wiring
Dear sir
      thank you for reply.thank you for wiring cable .but contain FX-232AW this function can be make ?if you can please send me the wiring for it.
thanks
best regards
The FX-232AW is an RS232 to RS422 converter with extended list of signals, and you can not repeat its schematics alone. You should use standard accessories for this connection, at least like SC-09 cable.
1 person likes this
Dear sir
        thank you very much .the FX-232AW contain two parall port one from plc and other in the personal computer but not contain db9 port so i f I want used laptop computer which contain db9 port what is the solving.
Just buy a cable.  Mitsubishi PLCs use RS422, your PC is RS232.  At a minimum you need a converter.
FX-232AW has 2 25-pin serial ports, not parallel ports.
Dear sir
       thank you for interest , please see photo I make direct cable between plc and laptop but not connect why?
For goodness sake save yourself time and heartache and buy a lead at only $6.00 it's a no brainer.
SC-09 cable
Steve
Dear sir
    thank you for interest but the soket in plc contain 25 pin so the sc-09 cable not used in this plc .please send me the suitable cable beteen plc fx-32mt (25 pin) and laptop (dp 9 pin)
This image is found on page 4 of this post. As you can see, you will need electronic conversion between the 25 pin and the 9 pin. This is why your direct connection is not working.
Dear sir
    thank you for interest but the plc  fx-32mt is contain soket 25 pin female not  contain in the attach photo so the cable is between 25 pin female and dp 9 male such as drawing in attache file  please send me the suitable wiring cable connection
Sigh, as nephets says, buy one for £5
The SC09 has a 25 pin plug and socket.
You pull it apart when you need the 25 pin part
MrPLC_SC09_Explained.jpg.80cd4daaa899bdc
The section on the left side is an adaptor for the newer PLCs. You only need the cable on the right side. It is the correct gender. There is a converter inside the 25 pin hood. A direct (Pin to Pin) connection will NOT work.
Dear sir
    thank you for interest .thank you very very much
SC09 is two pieces and has both 8-pin round and 25-pin PLC plugs, as was visible in this thread.  .
On 2/20/2004 at 0:38 PM, Sergei Troizky said:
Most probably, not all the communication settings are OK. Also, I would test the converter with anything else. A serial mouse is good enough, if you can get one. Or try another brand PLC, with RS232 programming port. SC-09 also should be tested on another PC with a serial port.
Great work with the diagram. I have many cables with 6 and 8 pin mini din type connectors and I suggest to people that they should label their cables. This will save frustration when you have identical looking cables that are wired differently.
SC-09 cable
Steve
By this post I am in tears.
Hello, does anyone have the pinout or schematic with the integrated ones used for the sc09 cable? I need db9 to db25 for a fx series plc. I read the whole forum and the images were deleted
PD i can't buy a cable because of the time to arrive to my country
Thanks
The images are all still there.
Thanks
I don't know what more information you need than what is provided in this thread already.
