glcon12
90-30 CPU311 firmware hex
2 posts in this topic
Hello, I am trying to connect with a PLC 90-30 series (IC693CPU311) from VersaPro, but is not possible. The connection from Logic Master is succesful. In Versapro help I read that Minimum Revision Level (Firmware Revision) is 8.21 to work with PLC (my PLC has earlier firmware version). Has anyone a newer than or equal 8.21 version in a HEX or BIN file format?
To upgrade firmware in a CPU311, you need to purchase an EPROM from your distributor. Part number is 44A731233. The list price is $100. You can set up VersaPro to permit downloads to earlier version levels. Open the 'Options' window and select the 'Communications' tab. There are three radio buttons to select which level of firmware revision checking to apply.
