Posted 19 May 2005 Hi everybody. Any body can let me know can i connect my PC to the Omron CPU peripheral port without using the Omron adaptor ?? Share this post Link to post Share on other sites
Posted 19 May 2005 (edited) You can't. At least not in a legal way. You can check the topic To connect CPM1 to PC without using CPM1-CIF01. At your own risk Edited 19 May 2005 by PdL Share this post Link to post Share on other sites
Posted 19 May 2005 Hi, Why not just buy the adapter (and charge your customer if you can - and even make some money out of it!!)? The time you play about with 'alternate' methods, the real thing will work out cheaper, it comes with a warranty as well!! Nibroc Share this post Link to post Share on other sites
Posted 28 May 2005 He was talking about CQM1. CQM1 is equipped with built in RS232. You can connected directly to the CPU without CQM1-CF01 adapter. You can buy the RS 232 cable, its common cable. or you can make by your self, many threads showing how to make this cable (pin arrangement). Share this post Link to post Share on other sites
Posted 30 May 2005 Hi everybody, Thanks for ur reply and help. I had bought a adaptor for the CQM1 cpu to interface to my PC. I did not use the build in RS232 port because it is connected to the HMI, and needed to be connected all the time . Share this post Link to post Share on other sites
