korted123
VBA control of serial port
11 posts in this topic
Hello, I am trying to send/receive information via my serial port, and am having a strrange problem: I can read and write successfully via VBA only after establishing a connection with hyperterminal and then closing hyperterminal. I am using simple commands like: Open "COM1" For Output As #1 Print #1, "Text" Close #1 The VBA itself will not establish the serial connection, but works fine after initialization by hypertermial. Any ideas??
You might have to use the MScomm module: Private Sub Form_Load() Dim str As String MSComm1.CommPort = 1 MSComm1.Settings = "9600,n,8,1" MSComm1.InputLen = 0 MSComm1.PortOpen = True MSComm1.Output = "hello" MSComm1.PortOpen = False End Sub This is off the top of my head....but see if it works.
This is the syntax for QBASIC or GWBASIC. Chakorules is correct when using Visual Basic for Applications
It's under Additional Controls
I ran the following: Private Sub Form_Load() Dim mscomm1 As Mscomm Dim str As String mscomm1.CommPort = 1 mscomm1.Settings = "9600,n,8,1" mscomm1.InputLen = 0 mscomm1.PortOpen = True mscomm1.Output = "hello" mscomm1.PortOpen = False End Sub ...and received the following error: "Object variable or With block variable not set (Error 91)" I can delete the mscomm1 declaration, but only get a different error. What am I missing?
...and I have the reference "MS COMM Control 6.0" added...
I believe you can remove the following line since it is already refrenced as a control. Then what error do you recieve?? Dim mscomm1 As Mscomm If you recieve "Object Required" you need to add the module onto the form. JJ Edited by TechJunki
We're getting closer...when I try to add MSCOMM to the form, I get: "The control could not be created because it is not properly licensed" The help for this item does not exist. How do I "properly license" this? I have tried both references and additional controls, where MSCOMM is selected, but the error remains. I keep looking within VBA, but see no other means of installing or registering this.
There are a couple of versions of the VB6 development package. The Professional Edition includes the MSCOMM object. The Student Edition does not. If you try to add the MSCOMM object to a form under the Student Edition, you get that message about licensing. The VBA included with Excel (or whatever VBA you're trying to use) may not let you design around MSCOMM objects. It may only let you use then at runtime. One other possibility to check is to look for a file called 'MSComm32.ocx' on your computer. It's normally found in the Windows\System32 directory.
You should be able to edit an excel file with the MSComm object already embedded. Try this, let us know if it works. JJ MSComm.zip
That works great! I can edit to my hearts content, too. Now all I need to do is get this to run as well in RSView32 as it does in Excel... Thanks Guys!!!
