Mahmoudmosad.aw
Hsc in fx3g cpu syntax error
2 posts in this topic
Good day to all
I have a problem in mitsubishi plc FX3G cpu. I want to make a modification on the program and make hsc 2 phase 2 count by A and B but in every time the same problem  syntex error 6504. I tried channel x000 for A and the other channel x003 for A. And the same problem.
I want to use hsc with A,B at x000 , x001.
Please if anyone can help me
Thanks
There is a table in the FX3G manual that says which inputs require the use of which counter numbers.  You have to follow the options in that table.  If you use those inputs in the program, you will get a syntax error.  To use X0 and X1 as two phase counter, use the counter numbers below.
C251 (without reset)
C252 (reset on X2)
C254 (reset on X2, start on X6)
